Problems with contiuous sampling using Labview for Arduino interface
So far I have been able to establish an connection between my arduino and the labview software with the LIFA base and also have gotten the continuous sampling example vi running and outputing data from the thermocouple I have it connected to.  The problem is I want to add on to this sub vi to output a temperature instead of a voltage reading from the thermocouple and have reproduced the example but the vi is not running past the initialization block and I am wondering if this is becasue im having registering problems with my VISA? Please help. the Vi is attached below
(4,555 Views)
The attached VI works perfectly fine for me. Is this the sub-vi you are trying to use, or is the the top-level vi?
(4,526 Views)
