Problems with the ethernet to GPIB connection
Hi guys,
I'm having trouble getting any data (except erros^^) from an Ahlborn Almemo 5690-1M
I'm using as mentioned an Ahlborn Almemo 5690-1M which is connected via a GPIB to Ethernet adapter to a small ethernet-switch that is also connected to my Notebook.
On my Notebook there's a Virtual Machine Installed(Win 10 Pro) an in that Virtual Machine I have installed LabVIEW 2013 together with the NI Systemconfigurator, NI VISA, NI-Serial and NI-DAQmx.
My problem is that everytime i try to use the VISA Test Panel and click on "Read" it says "VISA (Hex 0xBFFF0015)" and if I click on "Read Status Byte" then it's prompting me with "VISA (Hex 0xBFFF003A)", up untill now i haven't found any solution for my problem  and this is driving me crazy, please help me.
(3,330 Views)
I can easilly imagine why that would drive you crazy.  Which interface card are you connecting to the 5690-1 at A1?
There isn't a GBIP option available that I can see
(3,282 Views)
hi,
sorry it took so long to write back for the connection I am using the ZA 1919-DKU cable and I also have the ZA 1945-DK cable. Right now I have the ZA 1919-DKU connected to A1.
(3,256 Views)
