Program Error
Hello All
I have created all the necessary subVIs for making the instrument driver.But the utility folder that has some Vis got deleted because of which certain Vis does not run anymore. However, I have rewritten these Vis and placed these blocks inside other Vis which need these functions and all the connections are perfect. But still the program says that the subVi is missing. Can anyone suggest how to deal with this problem?
Message 1 of 1
(4,430 Views)
