Prologix GPIB-USB with HP4824A using vb6
Hello.
I am new to vb6 and instrumentation.
I am trying to write a software that will control the HP4284A LCR meter using vb6. The meter is connected to the PC using a Prologix GPIB-USB controller. What I do is I first send the command to the controller ++mode 1, and ++auto 1 and ++addr X.
Then in order to control the LCR meter can you please tell me as to what I need to do?
Thank You.
Message 1 of 23
(6,268 Views)
@kozxmartt wrote:
Hello.
Thank You.
Since you are using Prologix (not NI) and HP4284A (not NI), and VB6 (not NI), why are you posting here at a NI forum????
Message 2 of 23
(6,266 Views)
I meant to say Labview instead of vb6
Message 3 of 23
(6,263 Views)
Message 4 of 23
(6,261 Views)
Thanks, but are there any non ftp links, as Im unable to download from them.
Message 5 of 23
(6,258 Views)
That is a tutorial page for you to get started with LabVIEW.
Message 6 of 23
(6,253 Views)
I fairly know how to use Labview, but the main problem is this Prologix Controller. I have downloaded the drivers for the HP4824A. Since this controller makes the GPIB act as a virtual serial port, what changes do I need to make in the driver in order for it to work?
Message 7 of 23
(6,229 Views)
You need to get the LabVIEW examples from prologix.
Message 8 of 23
(6,223 Views)
I have the examples from Prologix too but the thing is that the HP4824A uses GPIB commands whilst the controller acts as a virtual serial port.
Message 9 of 23
(6,217 Views)
And what is confusing about the example? I see that for VISA you have to append a termination character for every write. I also see a compatibility layer for low level GPIB functions that you can download and do a search and replace if the driver does not use VISA for GPIB.
Message 10 of 23
(6,211 Views)
