Question about continue sent GPIB comand!
    I have  a old instrument( made in about 1990).It   have 2 GPIB device address, one for  sending  a  command byte,another for sending a parameter byte.  When I sent the command and parameter separately , that instrument running well.
 Code :
   CommandDev.write( Command_code  );  //press the windows bottun
   ParameterDev.write( Parameter_code );  //press the windows bottun
However when I continue send GPIB command, the instrument not work.
Code:
  CommandDev.write( Command_code1  );
  ParameterDev.write( Parameter_code 1);
 ParameterDev.write( Parameter_code 2);
 ParameterDev.write( Parameter_code 3);
  ParameterDev.write( Parameter_code3 );
     .                                                               //press the windows bottun
I have used NI spy.The capute data of those 2 case  is same .
How to  resolve this problem??
(3,827 Views)
The problem have been partly resolved, when I set 100ms delay time between the two command.
But  I found I must running the NIspy first, then Instrument    running well. If not , the instrument  not work.
(3,805 Views)
Another option is also to slow down the hardware handshake of the gpib interface.
For old instruments the best you can do is make it 2 microseconds, I don't have a gpib interface at home so I don't know the exact naming.
It allows for 3 or 4 settings with the slowest 2 microseconds. (use Measurement and Automation explorer/ devices and interfaces/ GPIB interface to see the setup)
And do remember that NI-spy also adds a minor delay to the  send/receive process, so you are correct when adding delays.
greetings from the Netherlands
(3,798 Views)
