Question on GPIB command 'FETCH:WQUALITY:PILOT' on 8960
I am a little bit confused about this command:
http://wireless.agilent.com/rfcomms/refdocs/cdma2k/cdma2000_hpib_fetch_wquality.php#FETCWQUCDPPIL
The description of its return value is as below:
Range:
I channel or Q channel: 0=I, 1=Q; 9.91 E +37
Walsh code: 0 to 15; 9.91 E+37
Spread Factor: 2, 4, 8, 16; 9.91 E+37
Code Domain Power (spread factor 16)
Total Code Domain Power (summation of spread factor 16 code domain power measurements useful for reverse supplemental channels at higher data rates): 0.0 to -40.0; 9.91 E+37
Total Code Domain Power Relative to Reverse Pilot (relative to total reverse channel pilot): +15 to -8; 9.91 E+37
I do got 6 comma sepearated values there:
+0.00000000E+000,+0.00000000E+000,+1.60000000E+001,-5.33195600E+000,-5.33195600E+000,+0.00000000E+000
I am not sure they are only values of Code Domain Power or already containing walsh code and spread factor.
I would like to get Walsh code andspread factor from here.  Could anyone give me some idea ? Or I have to use some other commands to do it?
+Kunsheng
(3,323 Views)
Accepted by topic author Kunsheng Chen
sorry.. I guess I found the problem.
thanks for any attention,
+Kunsheng
(3,322 Views)
