I was wondering if someone could help me understand the USB-8451 device a little better. I have been attempting to use the SPI write command as well as the DIO line write command within the same program (Note: I am not using the SPI DIO line write command as, for some reason, this does not seem to work. Also, the purpose of the DIO line write command is to send a pulse to an external flip-flop to signal that the data has been sent), but when the SPI write command executes it seems as though the DIO line floats high, producing undesirable effects in my design. I have attached a copy of the Labview program I have been using to test my design, as well as a test file. Could someone offer an explanation as to why I am encountering these effects, or possibly even suggest some improvements for the program. Thanks.
Andre
