RCX and LAbView
Hello! I want to program the Lego RCX brick via LabView! I've achieved that by using "robolab for labview". Could I avoid Robolab, because it seems to be adding 2 to 5 seconds of random delay before the RCX executes motor commands. Will it work if I run a vi that sends the RCX's opcodes through the serial port or is it much more complicated than that? I'm guessing it all comes down to driver programming,right?
Thank you in advance
(3,047 Views)
If you're using serial commands, you'll have to use some sort of driver to communicate with the RCX. You might have more luck posting on the Educational Support Forum, which handles all the LEGO related forum posts.
Jake H | Product Manager
(3,032 Views)
