RFID Reader - Labview communication
Hello sir,
i am trying to check if their is a connection between my pc and the reader. So i ran the demo software then tried to run my VI, and i got an error at the VISA close vi. Does this mean that there is indeed a communication?
thank you
Message 11 of 14
(1,850 Views)
Not necessarily. If the error occurs at the open visa it will also appear at visa close.
You could run the vi in debug mode to see if all goes well in each step.
In the blockdiagram cmd line click on the debug lamp bulb. Then press the run button.
greetings from the Netherlands
Message 12 of 14
(1,845 Views)
Hi Sir,
Actually i am not using an open VISA vi., i have the Write/Read vis initialized by the VISA configure vi.
But what i described above only occurs when i run my code in parallel with the demo software.
kindy find my vi attached.
Thank you,
Fady
Message 13 of 14
(1,843 Views)
can anybody downgrade this VI to version LV13?
*****************Certified LabView Associate Developer****************************
Message 14 of 14
(1,606 Views)
