RFID read module to interface with labview getting error 56 need support
Hi Team,
iam trying to interface a RFID device with labview which reads the tags within 150 meters continuously .its working with the Vendor application please find the attachment of the reading. need any VI to read from the Device and display in labview or support how to proceed with it.
tried using TCP/IP basic VI examples same issue persist.
Thanks in advance!!!
(2,478 Views)
Hello, Raj, I am having a similar problem. My RFID device is working, but I am trying to create a VI to read the data and display it in LabVIEW so I can use the info for other commands. Did you find a way to read the data in LabVIEW? I have also tried with TCP/IP examples and haven't found success. Please let me know if you can help, I would appreciate it a lot. Thank you!
Bryan
(1,638 Views)
