RRGGBB to RGB
Hallo,
How can I change the pixeldepth of the Color Box from U32 (4 bytes) to U16 (2 bytes) in RGB format:
R4R3R2R1R0G5G4G3G2G1G0B4B3B2B1B0
where
MSB: R4R3R2R1R0G5G4G3
LSB:  G2G1G0B4B3B2B1B0
for example i will get the representatoin in hexa as FFFFhex instead of FFFFFFFFhex for the white color.
many thanks if you can help
regards
Mahon
(3,230 Views)
did you check the function "split number" in the data manipulation palette?
greetings from the Netherlands
(3,226 Views)
