ā01-13-2009 04:08 AM
Hi, i am using Labview 8 for Fluke hydra dataloggers. But programm offenly shows an error either saying "at property node (arg1) in visa configure serial port (instr).vi" or "Occured at visa write". Gives the possible reasons as "resource is valid but visa cannot currently access it" or"Insufficient location information or the device or resource is not present in the system". I am not able to understand problem is with port or an instrument or with USB to Serial converter which i am using to connect the dataloggers to the computer.
Please help me in this reagard.
ā01-13-2009 12:25 PM
ā01-19-2009 01:25 AM
Hai, Albert
The "visa configure serial port (instr).vi" error has been rectified and the programm is running fine. Actualy i was configuring the port only once (i.e outside the while loop) when the programm starts. Now i am configuring the port after each output from the Hydra.
I would like to know, is this related to buffer memory?.
ā01-19-2009 01:47 AM
Hai, Albert
Fluke Hydra usualy gives the output in string form contains the last scanned values of all the channels.Output value is a signed number with decimal point and exponent as u can see below. But the thing is Read string is not able to get the sign of the first channel as highlighted below.
0019.5E+0,-0024.4E+0,+0023.7E+0,+0093.9E+0
Please help me in this regard,
ā01-20-2009 03:15 PM
Hi
sorry that I did not answer faster.
You probably solve a problem in the string read by reopening the port and at the same time crash the first character to be read.
How about flow control?
Do you have an end character defined? And maybe also enabled the endcharacter?
Try to read again after the first string to see how many characters are left?
ā01-21-2009 12:40 AM
Thanks, for your response.
I have selected flow control none.Enable termination char is set to false.
I have modified the code by adding the followings in series as given below.
Outside the while loop (VISA open-Set Buffer for write-Set Buffer for recieve-VISA serial config).
Inside the While loop (Flush buffer with mask 16 and 32-VISA Write for commands-VISA read). Tell me is this correct.
As you told, i am getting the same string twice. i am seperating the first string and sending to file.
I am opening and closing the port only once (both are outside the while loop).
I have three dataloggers of Fluke make with RS232 communication.As each com port can take only one instrument. Is there any other way so, that i can get all the data loggers programmed through Labview.
ā01-23-2009 12:08 AM
ā01-23-2009 11:20 AM
Hai,
Do you mean to say for each time I have to use VISA open and VISA close (inside the while loop) i.e. to read the data open the port and close once read,is it like that?
I thought of putting flush inside loop just because I experienced that the instrument simply stops after few hours of run and never accepts any
command until it is restarted. I guessed it is because of write memory exceeded.
And if I connect the three data loggers to individual com ports should I program in sequence. i.e.Open the first port-close it after reading the data and go for the second port. OR can I open all the ports at once and close all after getting the data from all the instruments.
ā01-24-2009 12:16 PM
