RS-232 control of keithley 2000/ Driver problem
Hi All,
I am trying to take resistance and voltage readings from the back channels of a Keithley 2000 with the RS-232 connection. I have downloaded the driver and unzipped it in the instr.lib but labview doesn't seem to want to recognize any of the vi's (just gives me question marks). Have I unzipped it improperly? Also, tried moving the unzipped files into a folder file to no avail.
I would think that there is a simple way to write my own vi but I can't seem to be able to read from the buffer. It gives me Error -1073807339.
Using: Windows 7
Labview 8.5
Any help would be appreciated.
(3,952 Views)
Yes, you have an install problem. There should be a Keithley folder directly under instr.lib.
Your error could be due to any number of reasons. Common problems are mismatched port settings and the wrong type of serial cable.
(3,943 Views)
could you resolve your problem?
i have the same, can you help me??
(3,727 Views)
Please refer to this KnowledgeBase article for a method to resolve the question mark error in your palette.
Warm Regards,
Daniel Dorroh
(3,707 Views)
