RS 232 to USB and Blue Screen
For Windows XP - C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa.
For Windows Vista or later - C:\ProgramData\National Instruments\NIvisa
Message 11 of 17
(1,897 Views)
thank you for your support. the problem still exist and it cause the work to be stopped during the experimental work. could you give me other suggestions?
Message 12 of 17
(1,875 Views)
Which adapter are you using?
Message 13 of 17
(1,871 Views)
I used a commercial one I bought it from farnell. by the way I am using the visa 4.3 and last week I saw a new version 5.? do think that if I install the new version the problem will be solved?
Message 14 of 17
(1,868 Views)
you can try the new Version 5.3
install NI-VISA 5.3 from NI-VISA 5.3
or you use another Adapter, as already mentioned low cost USB-to-serial adapters do not fully comply with the serial specification and therefore do not support a lot of the functions that VISA uses.
Message 15 of 17
(1,866 Views)
did you solve the problem?
Message 16 of 17
(1,853 Views)
unforetunatly no instead in became worst. the restart of the computer happened faster that before
Message 17 of 17
(1,842 Views)
