RS-422 : data with 2 TermChar (VISA Event based program)
Hello Everyone,
I'm using Labview (8.6) to make a program that interacts with a measurement system.
The communication with the device is done trough a serial (Rs-422) port. The device sends messages at 5Hz rate after a request from the PC.
The structure of the messages sent by the device is always the same, with a known minimal length and a two-character terminaison.19200 baud , parity=none, bitstop=1, databits=8.
I'm trying to make an Event based program. Please find attached the example of vi that I use (8.5 version).
I have a lot of warnings and after 50 cycles an error comes if I don’t use the VISA Disable Event and VISA Discard Event. Il seems that the event FIFO is never emptied event if I use the  VISA Wait On Event at each iteration of the loop.
The warnings and error are also attached. It seems that I haven’t good understood the event based programming. Can someone give me an explanation, how does it work or give me another proposition to identify the end of a serial message with 2 TermChar.
Thank you in advance for your support.
Message 1 of 1
(3,571 Views)
