RS-485 SELF TEST
Hello. I'm using PCI 8431/8 model for commucating with RS-485.
Before devolping applications, I tested its 2 wire auto mode, but it doesn't work.
I think there's no need to connect pin 1(ground) for 2 wire mode,
but as documented in http://decibel.ni.com/content/docs/DOC-4169 , I connected ports same.
And I used MAX and changed mode to "2 Wire Auto".
then, I used hyperterminal (ofcourse I set all properties same)
but there's no response in hyperterminal.
What's wrong with me?
(3,311 Views)
I hope there is nothing wong with you 😉
A stupid question: Did you set both ports to '2-wire Auto'
Did you try the VI mentioned at your link ?
Kees
(2,966 Views)
