RS232 exotic baudrate
Is it possible to set an exotic baudrate with VISA ?
I need a baudrate of 62500 bit/s to communicate with a radar.
Any clues ?
(3,115 Views)
VISA will set any baudrate that the serial driver supports. However, 62500 is not a standard baudrate, and is not directly supported by NI hardware. If you're using an NI serial card, see the attached guide for modifying your hardware to support the odd baudrate.
(3,115 Views)
