*RST Command on a E5071C
Does anyone know if the *RST command affects the calibration of a E5071C?  I cannot find the answer anywhere.
Thanks in advance.
(2,175 Views)
I think it would be best answered by the manufacturer - you would get better visibility on Keysight forum than NI forum.
Santhosh
Soliton Technologies
(2,148 Views)
Most of the newer instruments will not lose their calibration information with basic commands like *RST.
If you saved (or not) different settings for any of these values listed in the manual in Appendix C on page 633 then it will default back to the factory settings for those Cal settings; however, those saved Cal settings can be recalled back as your desired settings.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,136 Views)
