Showing results forย
Search instead forย
Did you mean:ย
*RST doesnt't work
HI everybody,
I work with R&S FSW8 signal & spectrum analyzer and I have problem with communication through LV. When I use he MAX and try to do almost every command, everything looks good, but in LV when I try to do *RST  or SYSTem:PRESet command with GPIB write VI, nothing happens. But as I said in MAX it woks properly. Do anybody happen to know where could be a problem?
Many thanks for any feedback
(5,255 Views)
Accepted by topic author onbartik
did you add a CRLF to your cmd?
greetings from the Netherlands
(5,217 Views)
Well maybe not, because afte lunch it stared work ๐Ÿ™‚
(5,195 Views)
