RTS in 232
I've already posted, but....
Hi people,
   I already posted something like this, but not specific, so here I am again!
   I have 2 PC (1 ps and 1 Fieldpoint, no matter this...), and I make them communicate via 2 modems, base band.
   When I want to send (VISA write) some characters to the other PC, I have to set RTS signal ON (to make a request to send to the modem). Modem answer with a CTS signal, and then I write characters. This works, and the other PC correctly receive data.
    The problem is when I reset RTS (RTS = 0), to deactivate the carrier signal.  Because carrier can't stand on communication line. If carrier is always present, the other PC can't initiate a communication!
    When I put RTS = 0, the second PC receives "framing errors", and print faulty characters.  Why so? Is there another way to do what I'm aiming to do?
    I expected the driver to automatically sitch on RTS when I want to send data, and automatially switch off RTS when data are transmitted, (flow control:RTS/CTS), but it doesn't work! Carrier signal stay on!!!!  So I'm forced to set
and reset RTS programmatically......
    Help will be really appreciated!
graziano
(3,341 Views)
Check the answer to your other Forum Thread
AlessioD
(3,326 Views)
You can do the same with my answer!!!!!
 Thanks!
(3,321 Views)
