RTS output and Visa write not in sequence
I am asserting RTS, writing and unasserting RTS, as shown below. unassert/assert state doesn't matter, RTS write is happening out of sequence.
 However on the scope I can see write starts, then RTS is asserted and quickly unasserted before write completes. I tried synch and asynch write and just put a sequence frame to no avail. VI is attached. Please help. Thanks.
(4,309 Views)
Might want to check the following links:
How Can I Control the DTR and RTS Serial Lines in LabVIEW?
http://digital.ni.com/public.nsf/allkb/1ECEFAA7AD52994986256966005356EA
LabVIEW VISA Open/Close Session Asserts Serial DTS
http://208.74.204.114/t5/LabVIEW/Labview-VISA-Open-Close-Session-Asserts-Serial-DTS/td-p/1163857
(4,280 Views)
Thanks, yes, I am aware of the first link and the second link doesn't apply. The actual scope sequence doesn't match the VI/software.
(4,273 Views)
