Read bar code using KEYENCE BL-601HA scanner
        Hi all in the forum...
             Did anyone has work with a KEYENCE  BL-601HA bar code scanner,  This is a RS-232 scanner,  I'm trying to configure and read label with  the scanner
       but so far couldn't make it to work.   Need some help,   I have been trying with out succes.  My time is ending to finish my program.
              I'll really apreciate any data related.
               Reynaldo Lima Villarreal
               Test Equipment Engineer
Ing. Reynaldo Lima Villarreal
Ingenieria Electronica (I N G E L)
Reynosa, Tamps. México
Cel: +52 899 160-52-59
Email: reynaldolima@aol.com
(5,797 Views)
Have you been able to communicate with the device at all through the software provided by Keyence?  I would recommend establishing communication first with the device through the software provided by the manufacturer.  I found it here:
If you continue to have problems, verify that your serial port is working correctly:
[broken link removed; page no longer available]
You can also look for more troubleshooting information here:
[broken link removed; article no longer available]
Hope this helps.
Saludos,
Erin
NI Mexico
(5,781 Views)
   Hi Erin..
      Thanks for your feedback.  I already call Keyence and they send me the software for the scanner, I have
       my scanner working good right now, But I'm not using the software from  Keyence.  I read carefully the
        data sheets and I made the scanner to work.
       Now the problem I'm having is with IMAQ applicaction.    I need to overlay a rectangule over an  image
       I know there is a VI with a input ROI Descriptor,  but what I need is to overlay a rectangule just using
       4 numeric controls.    I'm thinking  two ideas,  1) Create a ROI Descriptor as a control, so far I couldn't
       figure out.   2) Using 4 numeric controls in a simple way.....
        I'll appreciate any help.
        All this is for a  automatic Inspection system that I'm currently developing.I have an 80% complete but
        need to depure a little more.
         Rlima
(5,761 Views)
