Read double
I have problems with Labview because when I use the Measurement&automation program I can read without any problem but when I use it in the example of Labview the programm reads each word twice and I have no idea how to find a solution to this problem.
(3,690 Views)
You're reading what and how? Is this serial, GPIB, or something else? What example are you using? What the make and model of the instrument?
(3,688 Views)
I´m reading the identification of the device that is a Tektronix TDS 2022 using GPIB, the example I´m using is GPIB.vi and I should read TDS..... and i read TTDDSS... if you need something more, just ask; and thanks a lot
Guillem
(3,684 Views)
Do you mean "LabVIEW<->GPIB.vi"? I don't know of any shipping example called just "GPIB.vi"? You're sending the command "*IDN?"? Even though the example uses GPIB and I prefer and recomend VISA, they should work the same. Have you tried using the driver available for the scope? You can download it here. You can also try the Instrument I/O Assistant if you've got a newer version of LabVIEW.
(3,677 Views)
