Read from MS2601B spectrum analyzer problem using GPIB
I have MS2601B spectrum analyzer (anritsu), I want to read measurement data through the GPIB  from MS2601B.MS2601B can connect with GPIB and if change the PID of MS2601B manually(using front panel) and MAX show that change of PID.
But when I write or Query command like "INI \n" or "*IDN?" ,using "NI-488.2 Communicator",I get EABO error, I also try other commands too but unable to get any response.
Structure of commands written in manual is
WRITE @101:"CNF 1MZ"
WRITE @101:"INI"
I am new to labview and spectrum analyzer.SO may be I am doing some kind of mistake. Does anyone know correct format of command for the MS2601B and guide me how to get the data from the instrument by GPIB?
I find  relative article but unable to solve it till now ,
http://forums.ni.com/t5/RF-Measurement-Devices/acquiring-data-from-old-spectra-analyzer-through-GPIB...
I am using "NI-488.2 Communicator", sample code given for .net for sending commands.
I attached screen shot of MAX with error and Version detail .
Any kind of assistance will be appreciated
Thanks  in advance
(3,980 Views)
Within MAX did you do a scan to find all instruments connected to the GPIB?
Regards
Ray Farmer
(3,955 Views)
I downloaded the driver from NI and it seems to what (\r)CR (\n)LF sent with every command. are you sending this.
Regards
Ray Farmer
(3,949 Views)
i've the same problem.
did you solved it?
Best regards
Daniele
(3,767 Views)
