Reading IVI FGEN signals
I think i figured out how to generate a signal using the IVI fgen driversto simulate a 5412 board. My problem now is that I have no way to observe this signal. Is there a tutorial somewhere that I can follow step by step to solve this problem?
Eric
(2,969 Views)
You can only see the output signal if you have an instrument (i.e. scope) connected to the output of the function gen and in simulate mode, you don't have any output to measure.
(2,966 Views)
