Reading magnitude and phase from lock-in simultaneously
Hi guys,
I need to read data from a lock-in. My VI works fine, but I've just realized that I need to retrieve not only magnitude, but also phase of the signal. I have to idea how to make it and be sure that they are retrieved at perfectly the same time?
If you take a look at the picture attached, you can find command "mag" that is sent to the lock-in (and afterwards I save it in a text file). How should I send "pha" for reading phase?  I'm afraid that inserting it in series will result in reading the phase of a signal some miliseconds after reading the magnitude.
I hope I made it clear and you get what I mean 🙂
(2,813 Views)
RTFM?  Sorry, my crystall ball unforeseeable dropped from the table, so as far only the manual of your lock-in device can answer that question. 😉
Greetings from Germany
Henrik
LV since v3.1
(2,757 Views)
