Reading measurements from Agilent 34972A with Labview
I'm trying to measuring from Agilent 34972a by using Labview with no succes. Already i tried the voltage-example from the agilent web seite but it not work. Always time out error. I read some threads here but not realy helped. Is there any working example to simply read any measurement from any channel?
thanks in advance
ilhami
(5,639 Views)
I would suggest that you first try the driver from NI instead of the Keysight. You have also not provided much information. What sort of physical connection do you have?
(5,633 Views)
ok now I got it.  I changed the voltage-example from Agilent to my  experiment. It is a thermocouple measurement with Ethernet Communication.
I had to change the voltage method blocks to Temperature.
(5,629 Views)
