Receiving error -50251 when adding a voltage channel in NI MAX
When I try to make a measurement with a SCXI-1125 controlled through a PXI-6259, I get the error -50251.
This happens in Measurement and Automation Explorer, LabVIEW and CVI.
I am almost certain I have a DAQmx conflict, but repairing the system with the National Instruments Software utility did not help.
LabVIEW 8.0.1 is installed on the system, and upgrading to a newer version currently is not an option.
CVI is version 8.5.1.
NI-DAQmx is shown as 8.1 in NI-MAX.
Any hints?
(3,842 Views)
Accepted by topic author Peter_Kelly
I would recommend updating your DAQmx drivers. The most recent version that still supports your version of LabVIEW is DAQmx 8.7.1.
http://joule.ni.com/nidu/cds/view/p/id/965/lang/en
Anjelica W.
Product Marketing Manager
FlexLogger and TestStand
(3,825 Views)
That did the trick.
I had tried that initally, but apparently had a corrupt download.  Some of the required files weren't installed.  So I went back to where I was.
Another download with the NI download tool got me what I needed.
Thanks for the direction.
(3,813 Views)
