Recover from VISA connection loss
Hi, my LabView application is to set a power supply, enable output, and monitor volt and current using VISA based drivers download from NI.  I would like to know if there is a way to recover VISA connection loss when it happens (e.g. cable problem, etc.) while VI is still running.  I hope something can be done in LabView so that if that happens,  I can reconnect cable and the application reestablish VISA connection and continuously monitoring the PS outputs without restart the application.  Thanks in advance!
(7,635 Views)
In your software, you would have to detect the error (likely from the error cluster), close down your VISA session, and try to conenct again.  Repeat until sucessful.  A State Machine would be a good idea of you really need to do this.
(7,615 Views)
This is what I tried.  I have an idle state reading volt and current from a power supply.  I added extra LV code in the idle state to detect errors.  If error occurs, the code closes the VISA and open VISA again.  To test, I disconnected USB/GPIB cable to the power supply for few seconds and connect it back.  It failed in closing VISA (-1073807338) first try and successfully in second try.   But it failed in opening VISA with error  -1073807194 - Possible reason(s):  VISA:  (Hex 0xBFFF00A6) The connection for the given session has been lost. In order to work again, I have to stop the appl and restart again going through initialization and setting volt and current and enable output.
(7,578 Views)
Don't let your user's near the connections!  but them inside a locked cabinet.  BETTER, Train them to respect a "Test In Progress" sign.  Cause them pain when they fail to do so!
(7,568 Views)
That is some of the best advice I have ever heard, Jeff.  My other suggestion: avoid USB.  I have had too many issues with it wiggling out when dealing with any type of vibration.  PCI(e) and GPIB seem to work a lot better.
(7,550 Views)
