Reinitialize cRio Ethernet port
We have a system with multiple cRios talking to a SQL server thru an LV based proxy app.  The Ethernet ports are randomly disconnecting from the proxy and require a hard reboot (the power to be cycled) on the cRio to re-establish the connection.  This requires the tech to climb a ladder and toggle a breaker.  Is there a way to programmically force a hard reboot?  Also, any insight on what would cause the ports to disconnect from the system would be helpful.  It appears to be the TCP ( and maybe the UDP) traffic, the cRios can still respond to a ping.
KS
Message 1 of 1
(1,174 Views)
