Remote control LeCroy WaveRunner 64xi with Labview about configure timebase
I'm using labview to control Lecroy waverunner 64xi.
Does anyone know how to change the timebase?
It doesn't work when I use the "Configure Timebase.vi". Even I use the example to change it, the oscilloscope still has no response for the timebase.
Here is the driver I used.
Best regards
Haojie
(3,622 Views)
Hi there,
Make sure you have specified VISA resource correctly. Make sure to give Position (in seconds). This should work for you.
Regards
Karthik.
(3,417 Views)
