Remote control of MSP-GANG (new programmer)
I'm trying to use the new MSP-GANG remotely and since I didn't found the answer that I need on internet, I open a new topic here.
What I need to do is to:
- Connect to MSP-GANG
- Load a config (for any new production batch)
- Interactive Process (Erase, blank check, program, verify)
- Read a memory sector and save the data into a file
So far, I was able to load the config (previously generated from the MSP-GANG GUI). Unfortunately, when calling the interactive process function, there is no action from the programmer. My first interogation is: is there any action or command required between the load config and interactive process needed? Does the .mspgangproj contains all the necessary config?
Also I need to save a memory sector into a file and save this on my computer (calibration values). It seems that there is no way to do this from the dll, only through the GUI. Does someone found a solution to this?
Thank you in advance for your precious help!
Julien
(1,364 Views)
Hi Julian
Did you ever find out how to use the new DLL for the MSPGANG programmer?
If so, can you share the code, please?
(1,240 Views)
