Retrieving NI-MAX cycle information
I would like to know how to retrieve the information from NI-MAX concerning the cycling movement in the interface 1D and send it to the controller by an application in Labview.
Is this possible?
Thank you very much for your help
(4,500 Views)
Sorry, but I don't understand your question. What cycling movement and what is the 1D array and what controller? Attach some pictures.
(4,497 Views)
Sorry, I ment interractive 1d.
Here is the picture
(4,491 Views)
Then it appears you posted to the wrong board. Try the motion control board. I would imagine that since you have the driver functions installed, your LabVIEW program can use the same functions as MAX.
(4,476 Views)
