09-14-2013 03:57 AM
Can we conduct reverse polarity test for sorensen Programmable power supply controlling using Labview. ?.
Plese advise.
09-14-2013 11:38 AM
09-14-2013 01:20 PM
Plese advise.
Simple, Connect to a test load, source a low amperage constant current, measure voltage across the load. Of course, this won't protect you if the operator changes the polarity of the meter too.
Better Solution: Hire competent operators. It is VERY dificult to code around incompetence.
