Rohde FSV rsspecan drivers doesn't work if compiled but does under LabView
Hi!
I'm developing a control application for R&S FSV Spectrum Analyzer, I'm using LabView 8.5 with the latest RsSpecAn drivers (1.11).
The application works well if run from LabView, but once compiled there are certain VIs that causes errors, this VIs are:
rsspecan Delete Transducer Factor.vi
rsspecan Configure Transducer Factor.vi
rsspecan Select Transducer Factor.vi
rsspecan Configure Trace Detector.vi
The error produced with this VIs is the same, the only thing that changes is the VI that triggers it:
Property Node (arg 1) in rsspecan_core_check_error.vi->rsspecan_core_attribute_write_string.vi->subrsspecan_core_attribute_express.vi:2->rsspecan Configure Transducer Factor.vi:Instance:Instance           5 44Saved   rsspecan Configure Transducer Factor .vi:1->rsspecan Configure Transducer Factor.vi->minimun.vi
This VIs performs operations essential to my application so I can't compile it until I have this solved. Do you have any advice in how to compile it in order to work?
I'm attaching a minimun project to reproduce the error, but for testing this is essential to have a R&S FSV Spectrum Analyzer... I'm not sure if anyone will be able to test this...
Thanks in advice
Message 1 of 1
(3,454 Views)
