Rotate the stage using SMC100
My goal is to rotate the stage 0 to 90 degree with 10 degree increment and save the data. I can rotate the stage manually but when I put the increment, it does not work. I adopted the diagram from this link:
http://forums.ni.com/ni/board/message?board.id=140&thread.id=34659
(3,460 Views)
You should post on the original forum since this code was written by that community member.
Anna K.
(3,435 Views)
Thanks for your reply. My goal is different because SMC100 can control many devices. I just need the code for increment where to put it.
(3,418 Views)
