Running Continuum ND 6000 dye laser in LabView
so sorry!  must have missed the initial email back in September...
here they are!
Message 11 of 31
(3,943 Views)
Thanks Carrie!  We will give these a shot over the next few days!
Message 12 of 31
(3,933 Views)
Message Edited by EEsRULEtheWORLD on 02-02-2010 11:36 AM
Sara Lewandroski
Applications Engineer | National Instruments
Message 13 of 31
(3,919 Views)
Hi Carrie,
Did you find that the regular windows software supplied with the ND6000 worked with a regular straight-thru cable, in contrast to the remote control setup (like your labview), which appears to require a NULL modem cable (Tx and Rx swapped as per the manual)?
RipRock
Message 14 of 31
(3,867 Views)
Hi Carrie -
I have been unable to get your code to work.  I think the code is fine, but it is something about our setup that seems to be the problem.
I can install a straight-through cable, and talk to the laser using the windows software.  I can record these interactions with PORTMON, and see that it is transfering odd commands ("8V2.99", "8D777664", "8G", etc).  I can turn off the software, and reissue the commands above in quotes, and I can hear the motors spinning (even if I don't know what the commands do).
However, if I put a NULL MODEM cable in, at best I can get the port to echo commands back at me.  Under no circumstances can I get any further response, and there is no sign of activity on the computer.  I am stumped.  Any ideas?
One final observation - it appears in your code that you set the stop bits to 2, which differs from the manual (1 stop bit).  Is this an error in the code, or a typo in the manual?
Many thanks,
RipRock
PS:  I don't know if this is verbotten on this board, but I could leave direct contact info if that would help.
Message 15 of 31
(3,841 Views)
Whoops - little missing text in the last message makes it hard to interpret:  Trying again:
I can turn off the software, and reissue the commands above in quotes _using hyperterminal_...
Message 16 of 31
(3,840 Views)
RipRock,
I'm not sure how much I can help, but I will at least try.  I know that when I installed a regular serial cable that you can buy anywhere, it did not work.  I had to wire up a serial connector using the wiring diagram they give in the manual (Option 2, figure 7.1 in my manual) to get the two computers (i.e. the one running windows 95 w/ DOS and the one running XP and LabView) to talk to one another.  I had to test the programs using the RS01.exe program given with the laser as well.  The latest version of the program (which i think I attached but I will again to be sure) has two stop bits.  I hope this helps, at least to start...
Carrie
Message 17 of 31
(3,824 Views)
Thanks for the info Carrie -
So just to be clear, did the windows program they provide for setting the wavelength and zero reseting the ND6000, running on the remote computer, work with a regular cable connecting the remote computer and the computer inside of the ND6000, or only with the one as described in the book (which is a NULL modem cable)?
What I am trying to say is the only way I can control it now is with their windows program running on a remote computer connected to the computer in the ND6000 with a REGULAR serial cable.  I was assuming the NULL modem cable was only required for Labview commanding (for some unknown reason).   Can you control the ND6000 on a remote computer (not the one in the ND6000) using a normal serial cable and the included windows program?
S-
Message 18 of 31
(3,818 Views)
This I do not know.  I should be able to get back to you in a couple of days about that (the laser's down for maintainance now)
Message 19 of 31
(3,816 Views)
Carrie -
I think I have finally grokked the difference between our setups.  I believe the issue is that I am only using one computer (case A, below), and I am guessing you are using two (or three, case B):
Is this the case?
Thanks again!
S-
Message 20 of 31
(3,766 Views)
