SCPI Command to make S Param measurement - Agilent N5227 A
I am using VISA to control Agilent N5227A over LAN. What is the command to make a new S Parameter measurement? Is it the same as reading & saving? (CALC:DATA&colon;SNP:PORTs: SAVE <num><filename>)?
Thak you
(4,766 Views)
Wouldn't this information be listed in your manual? If you think this command is correct you can simply try it
(4,748 Views)
It s not listed in the SCPI commands manual. Also, the above command doesn't work. I always get a timeout error, irrespective of how high I set the timeout value.
(4,726 Views)
If the command is not listed, where did you get it?
In any case, for instrument specific commands, the best thing to do would be to ask Agilent.
(4,722 Views)
