SCPI command for TDS510A through VISA
I've searched and requested for the labview drive of TDS510A. Unfortunately, I still can't find one and have not yet received response from NI. I tried to read the programming manual (https://www.i3detroit.org/wi/images/2/2d/460-ProgrammerManual.pdf) of  the said instrument and it has SCPI command. I learn that I can use VISA to execute the SCPI command but have failed to properly communicate with my instrument.
Is anyone kind enough to give me a pattern or an example on how to properly communicate with my instrument? I am using GPIB-USB-HS. My goal is to just acquire data (e.i sine wave) and its corresponding *FFT
*According to manual, TDS510A can also provide FFT.
Any help is greatly appreciated.
Thank you,
-Lorenzo
(4,437 Views)
There is a LabVIEW driver available that is labeled TDS5XX Oscilloscope.  It specifically mentions the TDS520 and TDS540, but it will likely be at least a good starting point for you.
Tektronix tktds5xx Oscilloscope
(4,420 Views)
Use the attached simple VISA vi.  Select your TDS510A connection as the VISA resource name and for the write buffer, enter
*IDN?;
Now run it and it should respond with the device information loaded inside the instrument.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,390 Views)
