SICK LMS 291
Problem happens when I try to use 500kbps with a serial to ethernet gateway recommended by Sick. I can use the user software from Sick to monitor the field, however, error 1073807330 appears when I use a LabView program downloaded from http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=523F16CDD397108FE0440003BA7CCD.... It works at 38400bps and it has a 500,000bps option on the front panel. Did anyone meet similar issue before? Thanks.
Message 11 of 13
(1,315 Views)
Hello Grace,
You may want to give us more description about the error that you are facing. What are the description of the err?
James
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
Message 12 of 13
(1,293 Views)
New thread started for this issue
Message Edited by NathanT on 09-14-2009 07:46 AM
Message 13 of 13
(1,283 Views)
