SImulate Fluke 5700A
Is there a LabView simulator for an HP (Fluke) 5700A?  I need to develop a control application for this instrument, but I don't have one available immediately (May be months to acquire one).
XL600
(4,057 Views)
XL600,
You can always use SCPI to program and query the instrument.  Look into the 'Remote Programming Reference Guide' for the commands that can be sent to the instrument remotely.  You simply need to use the VISA (Write, Read, and Close) primitives within LabVIEW.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,009 Views)
It looks like one doesn't exist. What function are you looking for? Maybe there's a similar application just for the function you need?
(4,002 Views)
I just need to simulate enough to get a VI written which will initialize and control the voltage output (On/Off, level) for an automated test.  Not having the instrument available makes this rather difficult if no simulator (IVI driver?) is available...
(3,999 Views)
This is an easy task.  The remote programming manual can be found at: 5700A Pgm Guide
Create a CASE statement for simulation and one for actuation of hardware.
  1. Make sure that the hardware when available, is connected and configured properly
  2. Perform a simple query (Unit should respond as stated in the guide)
    *IDN?
  3. Continue to setup the instrument as desired using the commands in the guide
  4. Add responses from the simulated case
(3,995 Views)
