Randy,
When I put a sys_exec vi and wire it up to run notepad, everything works fine. I am using 6.1 to build my larger application. My system has 1.5 gb of
ram. I am using windoze2000. The exe I am calling is
775kb. I tried calling the exe directly, and I get the same error message. I do not know what version of labview the application was built using, However it is using the 25 runtime engine.
fyi...
