Scale problem-Using labview to control a tektronix MDO3000 series oscilloscope
I have connected the oscilloscope to the computer,and  downloaded the oscilloscope's driver to control it.My problem is I want to show 100 cycles of signals on the screen,but when I run the VI,it automaticly show only two cycles on the screen.What should I do?
(3,256 Views)
You should ask more data.
That can be done in several ways, post your vi and the link to the driver so we can advise you more efficiently.
greetings from the Netherlands
(3,225 Views)
What is the frequency of the signal you are trying to capture?  You have to use that to determine how many data to capture.  The time you have to capture is T = (# cycles)/(Frequency of signal).  So if you want 10 cycles of a 10Hz signal, you have to get 1 second worth of data.
(3,193 Views)
I want to get 200 cycles of a 50kHz signal.My question is that I don't konw how to modify the oscilloscope’s driver.
(3,182 Views)
