Secmentation Fault GDB Debugger
i develop a programm under Linux Suse 9.2. To test and debug my Application I use the kgdb debugger. The problem is that every 488.2 funktionktion results a segmentation fault under gdb. The driver examples too. Under normal conditions, without gdb, the programms work normal.
Have anybody solution
Greets
A. Schäfer
(4,889 Views)
I have isolate a part of the Problem, during the board is in online mod, I can't step through the programm. The programm opens a second thread on the first GPIB call. little bit after this the thread resceive a Segmentation Fault signal, and died. How can I fix the problem?
(4,879 Views)
hello,
R&D knows about this problem and works on it.
regards,
robert h
national instruments
(4,873 Views)
ok 😞 thanks............
(4,871 Views)
Lemiras,
R&D is in the process of developing a fix for this.  I can't guarantee, but I can state with high confidence that this will be fixed in the next version of the NI-488.2 for Linux driver.  We understand that it is very useful to be able to use GDB to debug problems in a program.
Scott B.
GPIB Software
(4,864 Views)
I have the same problem with Mandrake 10.1.
Is there an alternate debugger that works with the NI 488.2 driver for Linux and that i can use to debug gpib-based  applications ?
Thanks in advance
(4,838 Views)
JCRZ,
Not of which I am aware, unfortunately.  If you do find one, please post it here.
Scott B.
GPIB Software
(4,821 Views)
