Selecting Correct Hardware
I'm currently trying to select the correct micro processor / hardware to run the LabView program I put together, but I'm having trouble finding exactly what I need for hardware. The hardware must be able to receive data via either Ethernet or USB from a Peiffer TPG-362 and able to output at least 24 VDC. It would also be nice if it could also send numerical data to a LCD or some other screen. The last part is not required but would be nice. Any advice would be greatly appreciated. I am currently thinking that the USB-6524, Part Number: 779640-01, will work but I want to be certain before I spend tax payer money on them.
(3,011 Views)
You had posted, "The hardware must be able to receive data via either Ethernet or USB from a Peiffer TPG-362 and able to output at least 24 VDC."  Just so that you understand, the unit does not output any voltage.  It has relays capable of handling up to 60Vdc (shorting to return or open).
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,929 Views)
I see it behaves like a contact. That would also work as I already have power in place.
(2,926 Views)
