Self-test failed - PCI6034E board
I am trying to get data acquisition going on an old Dell 8200 computer.
I am running a 2013 version of NI MAX on Win XP SP3, with a PCI6034E board. The installed drivers are recent.
I get the following errors:
Self-Test gives: "The self-test failed -200020"
Self-Calibrate gives: "The device could not be calibrated -200251. No DMA channels or USB Bulk Endpoints are available..."
Test Resources button under Device Configuration gives: "The device is not responding to the selected base address"
Test Panel starts to plot a line under "Amplitude vs. Samples Chart", but then gives the error: -200019. "Possible Reason(s):
ADC conversion attempted before the prior conversion was complete."
Right now it's configured like this:
Memory Range              0xFE2FB000 - 0xFE2FBFFF
Memory Range              0xFE2F2000 - 0xFE2F2FFF
Interrupt Request           17
Direct Memory Access   0
Under Settings, it shows:
Name                      Dev1
Vendor                    National Instruments
Model                      NI PCI-6034E
Serial Number          FFFFFFFF
PCI Bus                  2
PCI Device              8
Status                     Present
The Win XP Device Manager does not list any device conflicts, and the BIOS recognizes the board.
Thanks.
(6,220 Views)
Hi Wave_monitor,
Can you please list the DAQmx driver you're using?  It's under the software tab in MAX.  Also, can you take a screen shot of the section of MAX you're working with?
Bobby Breyer
(6,185 Views)
The PC won't turn on at all now. I think the power supply is toast. It was acting strangely before - not turning on every time I pushed the power switch. Maybe this is related to the problem I was having? I guess we will find out when I get it fixed. Will post on the result...
(5,989 Views)
Sounds like a plan, thanks for the update.
Bobby Breyer
(5,949 Views)
Replacing the power supply solved the problem in my case. I am no longer getting those errors, and
'Test Samples' plots a normal curve. In general, the computer is responding faster now. So it seems the board
was just not getting enough power.
(5,593 Views)
Hey Wave_monitor
I'm glad you're up and running!
Bobby Breyer
(5,566 Views)
