Send "LLO" command using MAX (Measurement Automation Explorer)
Can I send a "LLO" command to A GPIB device using MAX?
And how.
Radu
(3,536 Views)
To the best of my knowledge, there is no way to send an LLO via MAX. Is there a reason that you wanted to do this? If you describe your reason, I might be able to come up with a viable alternative..
Best Regards,
Aaron K.
Application Engineer
(3,536 Views)
