SendIFC is not defined in NI488.h. What function replaces it?
We are porting our code from dos to windows.  Our code uses SendIFC frequently.  This function is defined in decl.h but not in ni488.h.  How do we reset the GPIB using the functions defined in ni488.h?
(4,757 Views)
Is there an ni4882.h file?
(4,733 Views)
The documentation for NI-488.2 still lists SendIFC as a valid function for C and VB.  Where are you getting your header files from?
Chad B. » National Instruments » ni.com
(4,728 Views)
No, I was able to down load: ni488.c, ni488.h, ni488225.exe, gpib.ini, CTA.c, GPIBini.c, Bdquery.c and ReadMe.txt.  I don't see anyway to download this file on the NI website.
(4,728 Views)
You should be able to access that function from the object file gpib-32.obj.
(4,692 Views)
Also, what hardware and driver are you using?
(4,655 Views)
