SendList and MakeAddr
I'm having a problem using the SendList function with secondary addresses.
I have an Agilent mainframe (primary address = 10) and 8 power supplies with secondary addresses of 96 to 103.
When I send a command, only the last power supply sets the voltage.  Does anybody know what's going on?
STDMETHODIMP CModularSupply::SetAllVoltages(double dVoltage, long *ReturnVal)
 int    j;
 Addr4882_t  instruments[9];   //Array of device addresses
 int    sad = 96;
 _bstr_t command = "";
 _bstr_t setvalue = "0";
 for (j = 0; j < 8; j++)
  instruments[j] = MakeAddr(10,sad);
  sad++;
 instruments[8] = NOADDR;
 setvalue = (double)dVoltage;
 command = "VOLT " + setvalue + "\n";
 SendList(0,&instruments[0], (char*)command , (long)command.length(), NULLend);
 if (ibsta & ERR){ *ReturnVal = FALSE;return S_OK;}
*ReturnVal = TRUE;
 return S_OK;
Curt
(3,287 Views)
What I'd do is try talking to just one power supply and seeing if that works. And keep adding more addresses to the array. It may be that you find you can't even set just one power supply.
(3,276 Views)
