Sending data serially from one port to another using VISA read/write.
I have found a program o Labview through which one can communicate on a single port using a loopback adapter.
But now I need to serially communicate between 2 different ports using labview..Plzz help
(4,702 Views)
It works the same way as a single port, you just need another loop to handle the second port.
(4,695 Views)
So what exactly is your problem? You use a null modem cable and use two different VISA Resource Names. This should be a simple modification. Show what you have done. Check the examples that come with LabVIEW. What's the point of doing this?
(4,693 Views)
